NO...My icons don't show in Cura when I open a project file that has been saved under any custom "PRINT SETTINGS" configuration. Ex.:
Setting up a new Named "Print Settings" or changing one of the default "Print Settings" (with changes) to a new name seems to be the issue as the defaults (like "STANDARD QUALITY - 0.2), WORK FINE. Yes some of my imported files from CHEP have #'s, "-'s" and/or a number but others don't. I have one project named "Guitar" if print settings are anything other than the default settings. Cura just shows the Cura ICON. FFV5.1TPU is another "CHEP" Settings file that doesn't show ICONS in explorer through CURA. I utilize the ICONS because I may have a bracket with a RH bend with three holes and another with a RH bend but holes are slotted and there's three additional holes. File names just don't lend themselves to visualization when items are complex and the file names get too long for a good description. I know theres other ways around this, I tried saving the project under a default setting (ICON showed), then opening the project and changing its setting to a custom setting and ICON went away.
MariMakes 204
Hey @ELDANS,
Your issue reminds me of this report we've gotten on Github:
https://github.com/Ultimaker/Cura/issues/14728
Could it be that you are running into the same thing?
Do you have custom printers with #s in the file names?
