Moonraker Error trying to send gcode from Cura 5.3 to printer
Ray14
Posted · Moonraker Error trying to send gcode from Cura 5.3 to printer
Hi All,
I have been trying to upload a gcode file to my printer (which has a Creality Sonic Pad) and I get a Moonraker Error - "There was a network error: Network error.ContentNotFoundError. Error transferring http://172.20.10.10/machine/device_power/device? Device=Creality Sonic Pad - server replied: Not Found"
I am completely new to printing wirelessly from my computer, so I have no idea how to rectify this.
Thanks in advance.
    ..... in addition, I am able to open 172.20.10.10 on my computer wirelessly and control the printer from there but I can't send files from Cura to the printer. I have been using a USB stick successfully until now, but that has it's own issues in use.
    • 4 weeks later...
    Posted (edited) · Moonraker Error trying to send gcode from Cura 5.3 to printer
    Hi i just managed to fix the exact same problem.
    Check if you have a A Name under "Power Device´s " in the Connection tab of the moonraker Plugin.
    Mine had Creality Sonic pad as it´s name and i tried to find a path to this name which is the reason it didn´t work
    If so delete the whole Line and try again
    Edited by DeathView
        • 56 replies
        • 34 replies
