If I click the circular arrow it changes the profile to a default profile which is not the current profile. The disk icon brings up the window I showed which is missing the discard current changes. Previously selecting discard current changes would remove any changes to the current profile and not go to a different profile. The only work around I have is to select a different profile, discard the changes at that point, then move back to the original profile.
On 4/6/2023 at 5:15 PM, iguanaman said:If I click the circular arrow it changes the profile to a default profile which is not the current profile.
As far as I know, it should do exactly the same as the "Discard current changes" menuitem used to do.
That seems to be a bug, worthy of reporting here:
https://github.com/Ultimaker/Cura/issues
Be sure to include your clear before/after situations.
- Solution
Submitted as a bug. Thanks!
ahoeben 1,986
See the "revert" icon here:
