Define Startup Orientation
Go to solution Solved by rburema,
Posted · Define Startup Orientation
Anyone know what defines the orientation of the workspace when Cura first starts up? Mine comes in at some arbitrary rotation and zoom level. Is it possible to change this to something more defined like the exact iso view with a zoom level to see the entire work envelope?
Small issue, but bothers my OCD that it is currently so arbitrary and I can't seem to find how to redefine it.
    • 2 weeks later...
    • Solution
    I'm afraid that's hardcoded at the moment.
            # Initialize camera
            root = controller.getScene().getRoot()
            camera = Camera("3d", root)
            diagonal = self.getBuildVolume().getDiagonalSize()
            if diagonal < 1: #No printer added yet. Set a default camera distance for normal-sized printers.
                diagonal = 375
            camera.setPosition(Vector(-80, 180, 700) * diagonal / 375)
            camera.lookAt(Vector(0, 0, 0))
            controller.getScene().setActiveCamera("3d")
    The values fed to the `setPosition` function seem somewhat arbitrary, to create a view that would look 'dynamic' to a designer maybe.
    In theory, you'd probably be able to make a plugin to set the camera to a more canonical position on start-up.
            # Initialize camera
                diagonal = 375
    Thanks for the response. Kinda figured this would be the case. Not a big deal, but a small UI nitpick that would be nice for super picky designs to have control over if possible someday.
        • 56 replies
        • 29 replies
