Can't Authorize to My S5 via REST API (Swagger UI)
Go to solution Solved by Hola_Adam,
Posted · Can't Authorize to My S5 via REST API (Swagger UI)
Hello, this is my first time delving into the API, and I'm struggling to even get authorized.
I've been interacting with my Ultimaker S5 (firmware 7.1.3) via the Swagger UI and I'm able to
  • POST /auth/request to get an ID + key pair after hitting 'Allow' on my printer
  • GET /auth/check with my ID which returns "authorized"
But then GET /auth/verify or GET /print_job/gcode just returns a 403 "Authorization required."
    • Solution
    Issues has been solved--I had missed the browser pop-up when I first did GET /auth/verify and it doesn't pop up on subsequent attempts. I restarted my browser, then input my ID and Key in as the Username and Password an everything works now.
    • Like 2
        • 56 replies
        • 34 replies
