New error : "this file does not match the fabrication volume" (my own translation from french)
Posted (edited) · New error : "this file does not match the fabrication volume" (my own translation from french)
Hey there,
I'm having an error I've never encountered before (there is still some haha !) : "this file does not match the fabrication volume".
It appears when I click on the white exclamation dot on the red circle, next to the print job which trigger this issue.
Actually, it even appear for my last 2 recent print job, which are using the same profile, and both of them are perfectly fine using CURA (Quality 0.15mm just a bit tuned) :
I don't know what's wrong, it fits the volume with some good margin. I really need to print this 2 files ASAP 😕
By the way, the error is my own translation from french "Ce fichier ne correspond pas au volume de fabrication". I tried to check the exact english error but did not find it yet.
Any idea ? I definitely can't share the 3mf unfortunately but as I said, just some basic Quality 0.15mm with 3-4 parameters tuned, the usual one i'm tuning for each print.
Edit, just tried scaling down to 75% and recentering the text (which is using the 2nd extruder for bi-color) and... It does not work either while margins are huges.
Edited by Dadkitess
        • 56 replies
        • 29 replies
