Sequential printing
Posted · Sequential printing
Hello all,
I use the sequential printing feature a lot, but I arrange the prints into a skewed grid from left to right, front to back, so that I can print full height and don't need to worry about the gantry hitting the objects.
However, it takes a bit of work arranging them like that, because there is basically no help from the software, for workflow that could be fully automated. Since I am new to this software it might be that I am doing something wrong, hence I have a few questions:
1) Is there any way to re-arrange the print order? Currently when I open multiple stl files, I have to slice them once and memorize the order, so I can arrange them properly on the build plate and then slice them again for actual printing.
2) Does there exist any plans to implement this kind of "limitless height sequential" printing feature, or is there a plugin for that? The marketplace offered nothing.
3) If not, does the plugin framework export such functionality (namely, re-arranging print order and object position)? If I get annoyed enough I might implement it myself then.
Any ideas and such regarding to this topic are very welcome, thank you.
        • 56 replies
        • 34 replies
