for example:
if I try to print a quader of exact 20.5 x 20.5 x 20.5 mm with 0.2 mm layers then I get a quader of 20.5 x 20.5 x 20.4 or 20.5 x 20.5 x 20.6 but not with the correct z-size. Especially if I use first layer height 0.3 mm.
In xy-direction I can reach nearly 0.01 mm resolution, but in z-direction the height of several horizontal surfaces depands on luck.
terory 0
Your idea might be reasonable but from the explanation I cannot understand what problem you are trying to solve.
