may have spoken to soon, this only works if first extruder is used last. what is missing in order to end on other tools? extruder_nr only points to first extruder in print end code.
- 2 weeks later...
- Solution
cura 5.4 beta has updates, and GregValiant has posted a post process script to include the last tool change, so no need to add {machine_extruder_end_code, Extruder_nr} to the printer end gcode
Thanks GregValiant, good work
FredFish 3
Found work around on redit,
added {machine_extruder_end_code, Extruder_nr} to end print code,
is there a better way to do this, like selecting if end code is added or not per tool ?
attached is my Direct ink writing implementation as sample coding reference
DIW-Direct_Ink_Write_setup-cura5.3.1(06032023)-3.pdf
