COM ports disable
8023
Go to solution Solved by DivingDuck,
Posted · COM ports disable
Hi, is it possible to add an option that completely disables the interactions with the serial COM ports, incl. the autodetect when cura starts?
Some of my devices do not like this and stop working.
Or is there a command line option that I haven't found yet?
        • 4 replies
