Posted (edited) · Nozzle dragging across first layer
My nozzle is dragging across the first layer, sometimes pulling the filament up with it.
It happens whether I use a glass bed or a spring steel bed.
I have:
Combing mode set to 'all'
'Avoid Printed Parts When Traveling' is checked
'Avoid Supports When Traveling' is checked
'Travel/Avoid distance' is 1mm
'Z Hop When Retracted' is checked
'Z Hop Only Over Printed Parts' is checked
'Z Hop Height' is 1mm
The higher layers seem to print well, I just can't always get past this first or second layer. Pulling the print off is very annoying.
It is a Revo Hemera head, not sure if that matters.
I am thinking of putting an endoscope on it so I can see why this is happening.
Edited by 3DPiper
