Entrelaced printing layer
Tangi
Posted · Entrelaced printing layer
Good morning,
I make quite a few functional parts with my printer, I design them in such a way as to stress them in the right direction of the layers... but there are parts that are constrained in several axes...
and clac, it breaks along a layer line (ultra solid in the cross layers on the other hand)
so the question is : does exist a printing mode where after 2-3 flat starting layers the print would start to dot on 2-3 layers before start waving until the end or it would end up with flat layers to finish, for the look the outer and inner skins could stay in 2D mode.
structurally we would no longer have these breakages following a layer, the parts would be strong!!
Maybe someone has already seen this!! or work on this futur mode?
Cordially
Tangi LE GALL
        • 26 replies
