Error: there are no compatible profiles with this extruder configuration
KoenP
Go to solution Solved by Cuq,
Posted · Error: there are no compatible profiles with this extruder configuration
I use cura 5.4 on Win11, Ender 5+ printer running klipper with moonraker plugin.
I installed Extrudr ASA material from marketplace, but when I select it I get that error and a yellow exclamation mark
How can I enable this material for my printer?
here are my machine settings:
2023-07-2611_29_38-Machine-instellingen.thumb.png.c0a8778f92aaa79d9cd0be38ff2ed5db.png
2023-07-2611_30_13-Machine-instellingen.thumb.png.1db3059030404f267b5493752a176627.png
the added material profile:
    Strange ,  When I load this material in Cura I have something totaly Different , The Default Color is Green and the Filament diameter 2.85 ( That's why why it shouldn't be  compatible with your Ender-5 extruder) . But You have a different configuration, With a price , the name itself is different. Is it an old material configuration file ?    Normaly you should event not see this material in the list if your Ender 5 is activated.
    Apparantly it is the same issue with every available ASA filament from the material library.... Could it be blocked in the creality ender 5 + machine profile?
    • Solution
    Posted (edited) · Error: there are no compatible profiles with this extruder configuration
    It's not only for the Ender 5 but for every Creality machine.  In the Extruder definition for these machines there is no ASA configuration defined in standard.
    You can find some configuration for PLA / ABS/ PETG / TPU  but No ASA , ToughPLA, PC, Nylon  etc.  If you want to use ASA definition you must add some Quality configuration for this material. base_0.4_ASA_standard.inst.cfg.zip
    Edited by Cuq
