CURA interlocking problem for Raise3D pro3 plus
lyon123
Posted · CURA interlocking problem for Raise3D pro3 plus
I am looking for using the interlocking function with raise3D pro3 plus with 2 nozzle machine, but in the CURA5.4.0, there is not raise3D pro3 plus to be contained in non-ultimaker printers.
so I try to get the Gcode from cura to raise3d ideamaker
But i find one part is in error location.
So any manito can help me? thank you very much at first
I wish that I can use cura with raise3D pro3 plus with interlocking function ASAP.
The interlocking is exactly cool function so that i can do more practical products with dual-material.
RN2PD_CuraCrocClipFlexible.gcode RN2PD_CuraCrocClipFlexible.stl RN2PD_CuraCrocClipFlexible.3mf
        • 26 replies
