Makerbot Replicator+, Macbook Pro, Ventura: No print option
Posted
· Makerbot Replicator+, Macbook Pro, Ventura: No print option
Hi Laura,
Im afraid this one might be not possible
While Ultimaker and MakerBot did merge to form UltiMaker
The cross support for product lines from the MakerBot side have not been added to UltiMaker Cura currently.
From my understanding the limited support for MakerBot Replicator currently is for the generations of Replicators before your Replicator+ and likely wont work for your machine.
Additionally it is generally not recommended to try and print over USB cable to any 3D printer in modern UltiMaker Cura as the function is mostly legacy at this point as modern 3D printers generally don't use this method because its very unstable.
Dustin 130
Hi Laura,
