Analyzing the sliced file in an analysis program such as Ansys
Posted
· Analyzing the sliced file in an analysis program such as Ansys
You.. kinda cant.
UltiMaker Cura is a slicer program not a CAD application.
The true output of UltiMaker Cura that includes support structure and infill is only gcode which is only lines of code for the firmwares motion systems.. its not a model at all..
You can find software that can render this into a 3d object on your computer.. but its not a model you can manipulate. its just a estimated rendering of the printing moves.
Dustin 130
You.. kinda cant.
