Forgotten / unprinted area
player107
Go to solution Solved by player107,
Posted · Forgotten / unprinted area
Hello
I am beginner to Cura 5.6.0.
I need to print the following part:
You can notice on the right that there is a bed. The bed is not printed (I 've done that 3 times from the beginning, still the same pb) :
I don't understand why,  since there is a full contact on the first layer :
I don't have the image but when I open the gcode file with cura, the missing part is there.
My printer is a D12 500 from wanhao.
Any Idea of the pb ?
The STL part is joined in case it would help someone.
Thank you in advance for your help.
Emmanuel
000-003-GOULOTTE.STL
