The UM3 was designed very flexible and has most of these values stored in an internal configuration file. It requires you to set the printer in Developer mode and then remotely log in to the Linux prompt to modify the file: /usr/share/griffin/griffin/machines/um3.json
Instead of modifying the 'e' value, you, of course, will have to modify the 'z' value.
Note that the Bondtech manual is old, the screenshots have the 'X', 'Y', 'Z' and 'E' parameters in capitals, with later firmware versions changed those to lower case letters.
CarloK2 1
The process is very similar to changing the E steps for people who upgraded the extruders. I'm lazy and redirect you to the Bondtech manual which explains this for dummies: https://support.bondtech.se/Guide/01. DDG For Ultimaker 2 and 3/16.html
See page 8 and further.
