Cura 5.6.0 won't work on my Windows 11--help?
terryalan
Go to solution Solved by terryalan,
Posted (edited) · Cura 5.6.0 won't work on my Windows 11--help?
Hello!
My wife got a 3D printer and I'm trying to set up Cura for her. Unfortunately, when I try to run it, it gets stuck on "Initializing package manager..." (image attached).
I have tried installing it to Program Files, Program Files (x86), and C://.
PC Specs
OS: Windows 11
Version: 10.0.22631
Computer Model: HP Envy x360
System Type: x64
Processor: Intel Core i7
Space: 512GB
RAM: 8GB
EDIT: Log file uploaded
Thx,
T
cura.log
Edited by terryalan
added log file
Posted · Cura 5.6.0 won't work on my Windows 11--help?
18 hours ago, Slashee_the_Cow said:
Your log file shows it running fine, including loading and slicing a model.
I just don't get why it's stuck on the blue screen 😞 Any tips?
    • 1 month later...
    I have the same problem. I don't think the problem is solved as marked. Using a previous version is a work around. I am investigating issues related to GPU but no succes yet.
    You're better off starting a new thread about it than necro-ing an older thread marked as "solved" if you're looking into it and need assistance or anything. The OP was satisfied with the way they dealt with the problem which is why they marked that as the solution.
        • 4 replies
