Cura stop jumping around
Posted (edited) · Cura stop jumping around
Two questions
First, how can Cura be set so it prints continuously? It starts printing in one spot then jumps to another, prints for a bit then jumps again. It seems to take much longer to print if it spends so much time jumping around. It also makes settings for stringing and retractions more difficult.
The other question is related. I want to use some multicoloured filament but when printing a simple circle it does the outside walls the jumps to the centre then halfway across. The multicoloured would not be printed as it comes off the spool mixing up the colours. I am using concentric pattern for infill, top and bottom layers.
Ender 3 Max, Direct drive extruder, Cura 4.13.1
Thanks to all
Edited by zappdog
        • 20 replies
