Query material settings from Cura Plugin
Go to solution Solved by bradk3,
Posted · Query material settings from Cura Plugin
How can my plugin get information about the currently-selected material?  For example, I would like to retrieve the brand, material type, and color.
I'm guessing that I should be able to find it through the active extruder stack, but my understanding of the stacks is embarrassingly limited.
    • Solution
    And, of course, after asking the question, I found the answer.
    For the benefit of future me, as well as others looking to do the same thing, you can, indeed, retrieve this for the active extruder stack.  For example:
    # Get the active extruder stack
    extruder = ExtruderManager.getInstance().getActiveExtruderStack()
    # Get the material for the active extruder stack
    material = extruder.material
    # You can retrieve the brand, material, and brand from the material metadata
    metadata = material.getMetaData()
    brand = metadata.get('brand', '')
    material = metadata.get('material', '')
    color = metadata.get('color_name', '')
