Cura Linux Slicing crashes: How to choose GPU or use only CPU?
Posted
· Cura Linux Slicing crashes: How to choose GPU or use only CPU?
Ah... damned... it's one of these cases when posting about the issue forces us to look deeper into it and solves the issue.
===== SOLVED =====
The "127.0.0.1" in the logs of 5.1.0 (above) alerted me on something... My "lo" interface was down and there was no route for it (due to some custom VPN scripts I made that apparently turned it down inadvertently).
So the solution was simply:
ifconfig lo up
ip route add 127.0.0.0/8 dev lo
(both as root of course)
That doesn't solve it for 5.6.0 which seems to be another issue, but that version 5.6.0 never worked for me anyway if I remember correctly.
FlorianBad 0
===== SOLVED =====
