Active levelling error Ultimaker 5S
Posted · Active levelling error Ultimaker 5S
Hi everyone,
I have a problem with the active levelling of my Ultimaker 5S.
when I start a printing process, the machine make the heating and then start the touching of the bed for the leveling and then start to print.
Usually, everthing goes well, but with the following configuration of the printing nozzle the machine do not start with the printing process.
Specifically The configuration is: PRINT CORE1: AA0.25 PLA PRINT CORE2: AA0.4 BREAKAWAY
All other configurations work well.
Also performing the manual levelling anything change.
Do you have any suggestion?
    Hi there! Your friendly assistant mod Slashee here. I don't know much about UltiMaker printers 😞 but the people on the UltiMaker Printers board do so I'm moving your topic there.
