How do I connect a Weefun (or Weedo, It's just a rebrand) to Cura wirelessly?
Go to solution Solved by Dustin,
Posted · How do I connect a Weefun (or Weedo, It's just a rebrand) to Cura wirelessly?
I've looked everywhere, and there seems to be no one who asks about this. My printer is connected to WIFI, but It's not showing up on the Cura wireless select screen.
    • Solution
    Networking support in UltiMaker Cura is typically designed for supporting UltiMaker 3d printers.
    3d party printers usually need a workaround or plug-in to make it work.
    You will likely get better advice for your issue reaching out to the maker of your 3d printer.
