8 minutes ago, Slashee_the_Cow said:If you could share the Cura project file (.3mf, in Cura go to File > Save Project) and post it that would really help.
Off the top of my head, try setting Experimental > Slicing Tolerance to Inclusive (if you can't see the setting just search for it).
Here you go.
Slicing tolerance improved the problem slightly, but the general issue persists. As in: The holes are still there, they're just smaller/shaped differently
Slashee_the_Cow 450
