Change UMC2+ connect nozel size when printing through digital factory.
Posted · Change UMC2+ connect nozel size when printing through digital factory.
Hi Guys,
I use a UMC2+ Connect fitted with a olsson block and a range of nozels from 0.25 to 0.8
Printer is running on the latest firmware.
I've recently had to switch from printing via the USB stick to going through Digital Factory.
When I was pritning on USB, I could change the nozel size in Cura then just press "accept" when the "wrong nozel size" warning popped up.
Is there any way to do this in Digital Factory? I can't find any way to change the nozel size in the mainteance menu on the printer or DF.
Many thanks for all your help,
Joe
