I included all speed settings to avoid questions. I thought the retraction speed is related to *filament* movement, not travel.
I do have the Autotowers plugin, that was how I noticed the limitation.
8 hours ago, Slashee_the_Cow said:Also retraction going up to 100mm/s sounds sort of overkill to me - I realise my Ender-3 V3 SE is hardly a high end printer but its direct drive extruder maxes out at 60mm/s and even then I never go over 45mm/s.
I was expecting that reaction. Yes, in general 80 mm/sec retraction is too high.
But I am not a general 🙂
My BMG geared extruder achieves 120 mm/s - but if repeating retractions in a row, I would risk slipping now and then.
I just found that in a specific case related to PETG and intricated models in a long Bowden setup the most effective way to avoid accumulation of oozed material in the travel path is to make the transition time between extrusions as short as possible. That means for travel movements: high jerk values (helps on short distances), high accelerations and high speed. The problem is, if you want a really clean printed part using PETG, and not to print it too slow, then fast travel movements are not enough in this case (direct drive might be different). The time spent while retracting also plays a role and it should be kept as short as possible - because even while retracting, material keeps flowing. Keeping a short time also implies *short* retraction lengths - the opposite as generally assumed. It is like paddling against the current in a river - you keep moving in the wrong direction, just a bit slower.
This is not just a theory. With this approach I am quite succesfull using PETG, but currently I have to use Orca for that because I have fast retractions then.
You should look at the nozzle after a print job using PETG is finished or just interrupting the job mid print - the filament flows and flows and flows by itself. How long would you have to retract to avoid that? Coping with this pressure is a challenge that demands non-conventional thinking. It makes no sense to retract longer if the the filament pressure overcompensates that movement at the same time.
I advice to open one's mind to information diverging from the "main stream", based on own experienced facts. I have gathered dozens of printed parts ("facts") and spent days (actually weeks) while playing with settings to avoid stringing. This is very specific to PETG in a long bowden system. Want more hassle? Use TPU. Or anything compressible.
But we are digressing. Still, no progress in my question: why is my retraction speed limited??
Slashee_the_Cow 421
The print speed/acceleration values have nothing to do with retraction - the retraction settings are in the Travel section.
There's a plugin available (just click Marketplace at the top right) called "AutoTowers Generator" with some preset towers (or with a teeny bit of hassle you can get it to make custom ones) which automates the process completely, all you have to do is pick the tower you want and save the gcode.
