Failed to upload the file error in Cura saving to Digital Library
Posted · Failed to upload the file error in Cura saving to Digital Library
While saving Cura projects to the Digital Library, I started getting this error today:
The error message is not specific enough to discern what the issue is, I'm not doing anything different than before when I didn't get the error - anyone know a resolution?  This seems to happen with any new project file.
    I'm having a very similar issue - files are not saved in Digital Library either, but I don't get any error message whatsoever.
    Looking at the logs it seems to be a similar issue though.
    Quote
    required.", "model_name": "FileUploadRequest", "field_name": "origin", "error_type": "ModelValidationError", "url": https://api.ultimaker.com/files/upload}}]}
    I contacted support; let's see what happens.
    Same issue with my windows version. 5.7.3.
    Can't save to my Digital Library. I'm connected and sync.
    I'm able to save to any disk.
    Hope this will be fix. Thanks
    Support just sent me an email that they fixed it, and that does indeed seem to be the case.
    • Thanks 1
