Issues by printing with Ultimaker 3 3Dwith layer 0.25mm
Posted · Issues by printing with Ultimaker 3 3Dwith layer 0.25mm
I have a 3D printer, the Ultimaker 3, and I would like to calibrate the extruder as I'm noticing some issues with print quality. Specifically, I see small defects on the walls, and it seems like some filament is oozing out between layers. Any solution?
Extruder temp: 205°C
Bed temp: 60°C
Print speed: 70mm/s
    Posted (edited) · Issues by printing with Ultimaker 3 3Dwith layer 0.25mm
    Let's start with the basics.
    Dry filament?
    Have you dialed in the flow settings?  See here
    What size nozzle/core?
    Edited by LePaul
    Right, if you are pointing out print defects, let's see what's creating them.
    The link I sent will demonstrate how to print a calibration cube.  With flow at 100%, print the cube and use calipers to measure the average of the 4 wall thickness.  That will tell you if you are over or under extruding.
