Posted · Extrusion width math not right
I have here a model of a 10x10x10 cm cube in Slic3r. I have set my extrusion width to 0.5mm (all of them),infill angle at 90 degrees, rectilinear infill, infill density at 100% and disabled perimeters. By my rather simplistic understanding of the situation, there should be 20 parallel lines per layer (10cm/0.5mm=20). However there are only 19 when I put the gcode through a visualizer.
Why is one line missing? Is Slic3r leaving out some space between lines on purpose? Is it trying to compensate for something so that it finally ends up with a solid part?
Here is the Gcode for the file.
; generated by Slic3r 0.9.10b on 2014-04-09 at 01:28:03
; layer_height = 0.5
; perimeters = 0
; top_solid_layers = 3
; bottom_solid_layers = 3
; fill_density = 1
; perimeter_speed = 30
; infill_speed = 60
; travel_speed = 130
; nozzle_diameter = 0.5
; filament_diameter = 3
; extrusion_multiplier = 1
; perimeters extrusion width = 0.50mm
; infill extrusion width = 0.50mm
; solid infill extrusion width = 0.50mm
; top infill extrusion width = 0.50mm
; first layer extrusion width = 0.50mm
G21 ; set units to millimeters
M107
M104 S200 ; set temperature
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
M109 S200 ; wait for temperature to be reached
G90 ; use absolute coordinates
G92 E0
M82 ; use absolute distances for extrusion
G1 F1800.000 E-1.00000
G92 E0
G1 Z0.500 F7800.000
G1 X90.400 Y90.400
G1 F1800.000 E1.00000
G1 X91.390 Y89.600 F600.000 E1.04502
G1 X92.510 Y88.990 E1.09012
G1 X93.730 Y88.620 E1.13521
G1 X95.000 Y88.500 E1.18033
G1 X105.000 Y88.500 E1.53401
G1 X106.270 Y88.620 E1.57912
G1 X107.490 Y88.990 E1.62421
G1 X108.610 Y89.600 E1.66932
G1 X109.600 Y90.400 E1.71434
G1 X110.400 Y91.390 E1.75935
G1 X111.010 Y92.510 E1.80446
G1 X111.380 Y93.730 E1.84955
G1 X111.500 Y95.000 E1.89467
G1 X111.500 Y105.000 E2.24834
G1 X111.380 Y106.270 E2.29346
G1 X111.010 Y107.490 E2.33855
G1 X110.400 Y108.610 E2.38366
G1 X109.600 Y109.600 E2.42867
G1 X108.610 Y110.400 E2.47369
G1 X107.490 Y111.010 E2.51880
G1 X106.270 Y111.380 E2.56389
G1 X105.000 Y111.500 E2.60900
G1 X95.000 Y111.500 E2.96268
G1 X93.730 Y111.380 E3.00780
G1 X92.510 Y111.010 E3.05289
G1 X91.390 Y110.400 E3.09799
G1 X90.400 Y109.600 E3.14301
G1 X89.600 Y108.610 E3.18803
G1 X88.990 Y107.490 E3.23313
G1 X88.620 Y106.270 E3.27822
G1 X88.500 Y105.000 E3.32334
G1 X88.500 Y95.000 E3.67702
G1 X88.620 Y93.730 E3.72214
G1 X88.990 Y92.510 E3.76723
G1 X89.600 Y91.390 E3.81233
G1 X90.353 Y90.458 E3.85470
G1 F1800.000 E2.85470
G92 E0
G1 X95.362 Y95.505 F7800.000
G1 X104.638 Y95.505 F693.500 E1.33137
G1 X104.638 Y96.010 E1.34942
G1 X95.362 Y96.010 E1.68079
G1 X95.362 Y96.515 E1.69884
G1 X104.638 Y96.515 E2.03021
G1 X104.638 Y97.020 E2.04826
G1 X95.362 Y97.020 E2.37963
G1 X95.362 Y97.525 E2.39768
G1 X104.638 Y97.525 E2.72905
G1 X104.638 Y98.030 E2.74710
G1 X95.362 Y98.030 E3.07847
G1 X95.362 Y98.536 E3.09652
G1 X104.638 Y98.536 E3.42789
G1 X104.638 Y99.041 E3.44594
G1 X95.362 Y99.041 E3.77731
G1 X95.362 Y99.546 E3.79536
G1 X104.638 Y99.546 E4.12673
G1 X104.638 Y100.051 E4.14478
G1 X95.362 Y100.051 E4.47615
G1 X95.362 Y100.556 E4.49420
G1 X104.638 Y100.556 E4.82557
G1 X104.638 Y101.061 E4.84362
G1 X95.362 Y101.061 E5.17499
G1 X95.362 Y101.566 E5.19304
G1 X104.638 Y101.566 E5.52441
G1 X104.638 Y102.071 E5.54246
G1 X95.362 Y102.071 E5.87383
G1 X95.362 Y102.576 E5.89188
G1 X104.638 Y102.576 E6.22325
G1 X104.638 Y103.081 E6.24130
G1 X95.362 Y103.081 E6.57267
G1 X95.362 Y103.586 E6.59072
G1 X104.638 Y103.586 E6.92209
G1 X104.638 Y104.091 E6.94014
G1 X95.362 Y104.091 E7.27151
G1 X95.362 Y104.596 E7.28956
G1 X104.638 Y104.596 E7.62093
M106 S255
G1 F1800.000 E6.62093
G92 E0
G1 Z1.000 F7800.000
G1 X95.505 Y104.638
G1 X95.505 Y95.362 F600.000 E1.33138
G1 X96.010 Y95.362 E1.34942
G1 X96.010 Y104.638 E1.68079
G1 X96.515 Y104.638 E1.69884
G1 X96.515 Y95.362 E2.03021
G1 X97.020 Y95.362 E2.04826
G1 X97.020 Y104.638 E2.37963
G1 X97.525 Y104.638 E2.39768
G1 X97.525 Y95.362 E2.72905
G1 X98.030 Y95.362 E2.74710
G1 X98.030 Y104.638 E3.07847
G1 X98.536 Y104.638 E3.09652
G1 X98.536 Y95.362 E3.42789
G1 X99.041 Y95.362 E3.44594
G1 X99.041 Y104.638 E3.77731
G1 X99.546 Y104.638 E3.79536
G1 X99.546 Y95.362 E4.12673
G1 X100.051 Y95.362 E4.14478
G1 X100.051 Y104.638 E4.47615
G1 X100.556 Y104.638 E4.49420
G1 X100.556 Y95.362 E4.82557
G1 X101.061 Y95.362 E4.84362
G1 X101.061 Y104.638 E5.17499
G1 X101.566 Y104.638 E5.19304
G1 X101.566 Y95.362 E5.52441
G1 X102.071 Y95.362 E5.54246
G1 X102.071 Y104.638 E5.87383
G1 X102.576 Y104.638 E5.89188
G1 X102.576 Y95.362 E6.22325
G1 X103.081 Y95.362 E6.24130
G1 X103.081 Y104.638 E6.57267
G1 X103.586 Y104.638 E6.59072
G1 X103.586 Y95.362 E6.92209
G1 X104.091 Y95.362 E6.94014
G1 X104.091 Y104.638 E7.27151
G1 X104.596 Y104.638 E7.28956
G1 X104.596 Y95.362 E7.62093
G92 E0
G1 Z1.500 F7800.000
G1 X104.638 Y95.505
G1 X95.362 Y95.505 F600.000 E1.32804
G1 X95.362 Y96.010 F7800.000
G1 X104.638 Y96.010 F600.000 E1.65609
G1 X104.638 Y96.515 F7800.000
G1 X95.362 Y96.515 F600.000 E1.98413
G1 X95.362 Y97.020 F7800.000
G1 X104.638 Y97.020 F600.000 E2.31218
G1 X104.638 Y97.525 F7800.000
G1 X95.362 Y97.525 F600.000 E2.64022
G1 X95.362 Y98.030 F7800.000
G1 X104.638 Y98.030 F600.000 E2.96827
G1 X104.638 Y98.536 F7800.000
G1 X95.362 Y98.536 F600.000 E3.29631
G1 X95.362 Y99.041 F7800.000
G1 X104.638 Y99.041 F600.000 E3.62436
G1 X104.638 Y99.546 F7800.000
G1 X95.362 Y99.546 F600.000 E3.95240
G1 X95.362 Y100.051 F7800.000
G1 X104.638 Y100.051 F600.000 E4.28045
G1 X104.638 Y100.556 F7800.000
G1 X95.362 Y100.556 F600.000 E4.60849
G1 X95.362 Y101.061 F7800.000
G1 X104.638 Y101.061 F600.000 E4.93653
G1 X104.638 Y101.566 F7800.000
G1 X95.362 Y101.566 F600.000 E5.26458
G1 X95.362 Y102.071 F7800.000
G1 X104.638 Y102.071 F600.000 E5.59262
G1 X104.638 Y102.576 F7800.000
G1 X95.362 Y102.576 F600.000 E5.92067
G1 X95.362 Y103.081 F7800.000
G1 X104.638 Y103.081 F600.000 E6.24871
G1 X104.638 Y103.586 F7800.000
G1 X95.362 Y103.586 F600.000 E6.57676
G1 X95.362 Y104.091 F7800.000
G1 X104.638 Y104.091 F600.000 E6.90480
G1 X104.638 Y104.596 F7800.000
G1 X95.362 Y104.596 F600.000 E7.23285
G1 F1800.000 E6.23285
G92 E0
G1 Z2.000 F7800.000
G1 X95.505 Y104.638
G1 X95.505 Y95.362 F600.000 E1.32804
G1 X96.010 Y95.362 F7800.000
G1 X96.010 Y104.638 F600.000 E1.65609
G1 X96.515 Y104.638 F7800.000
G1 X96.515 Y95.362 F600.000 E1.98413
G1 X97.020 Y95.362 F7800.000
G1 X97.020 Y104.638 F600.000 E2.31218
G1 X97.525 Y104.638 F7800.000
G1 X97.525 Y95.362 F600.000 E2.64022
G1 X98.030 Y95.362 F7800.000
G1 X98.030 Y104.638 F600.000 E2.96826
G1 X98.536 Y104.638 F7800.000
G1 X98.536 Y95.362 F600.000 E3.29631
G1 X99.041 Y95.362 F7800.000
G1 X99.041 Y104.638 F600.000 E3.62435
G1 X99.546 Y104.638 F7800.000
G1 X99.546 Y95.362 F600.000 E3.95239
G1 X100.051 Y95.362 F7800.000
G1 X100.051 Y104.638 F600.000 E4.28044
G1 X100.556 Y104.638 F7800.000
G1 X100.556 Y95.362 F600.000 E4.60848
G1 X101.061 Y95.362 F7800.000
G1 X101.061 Y104.638 F600.000 E4.93653
G1 X101.566 Y104.638 F7800.000
G1 X101.566 Y95.362 F600.000 E5.26457
G1 X102.071 Y95.362 F7800.000
G1 X102.071 Y104.638 F600.000 E5.59261
G1 X102.576 Y104.638 F7800.000
G1 X102.576 Y95.362 F600.000 E5.92066
G1 X103.081 Y95.362 F7800.000
G1 X103.081 Y104.638 F600.000 E6.24870
G1 X103.586 Y104.638 F7800.000
G1 X103.586 Y95.362 F600.000 E6.57675
G1 X104.091 Y95.362 F7800.000
G1 X104.091 Y104.638 F600.000 E6.90479
G1 X104.596 Y104.638 F7800.000
G1 X104.596 Y95.362 F600.000 E7.23283
G1 F1800.000 E6.23283
G92 E0
G1 Z2.500 F7800.000
G1 X104.638 Y95.505
G1 X104.638 Y98.030 F600.000 E2.96826
G1 X104.638 Y99.041 F600.000 E3.62435
G1 X95.362 Y99.546 F600.000 E3.95239
G1 X104.638 Y100.051 F600.000 E4.28044
G1 X95.362 Y100.556 F600.000 E4.60848
G1 X95.362 Y101.566 F600.000 E5.26457
G1 X104.638 Y102.071 F600.000 E5.59261
G1 X95.362 Y102.576 F600.000 E5.92066
G1 X104.638 Y103.081 F600.000 E6.24870
G1 X95.362 Y103.586 F600.000 E6.57674
G1 X104.638 Y104.091 F600.000 E6.90479
G1 X95.362 Y104.596 F600.000 E7.23283
G92 E0
G1 Z3.000 F7800.000
G1 X95.505 Y104.638
G92 E0
G1 Z3.500 F7800.000
G1 X104.638 Y95.505
G92 E0
G1 Z4.000 F7800.000
G1 X95.505 Y104.638
G92 E0
G1 Z4.500 F7800.000
G1 X104.638 Y95.505
G92 E0
G1 Z5.000 F7800.000
G1 X95.505 Y104.638
G92 E0
G1 Z5.500 F7800.000
G1 X104.638 Y95.505
G92 E0
G1 Z6.000 F7800.000
G1 X95.505 Y104.638
G92 E0
G1 Z6.500 F7800.000
G1 X104.638 Y95.505
G92 E0
G1 Z7.000 F7800.000
G1 X95.505 Y104.638
G92 E0
G1 Z7.500 F7800.000
G1 X104.638 Y95.505
G92 E0
G1 Z8.000 F7800.000
G1 X95.505 Y104.638
G92 E0
G1 Z8.500 F7800.000
G1 X104.638 Y95.505
G92 E0
G1 Z9.000 F7800.000
G1 X95.505 Y104.638
G1 X98.030 Y104.638 F600.000 E2.96827
G1 X99.041 Y104.638 F600.000 E3.62436
G1 X99.546 Y95.362 F600.000 E3.95240
G1 X100.051 Y104.638 F600.000 E4.28045
G1 X100.556 Y95.362 F600.000 E4.60849
G1 X101.566 Y95.362 F600.000 E5.26458
G1 X102.071 Y104.638 F600.000 E5.59262
G1 X102.576 Y95.362 F600.000 E5.92067
G1 X103.081 Y104.638 F600.000 E6.24871
G1 X103.586 Y95.362 F600.000 E6.57676
G1 X104.091 Y104.638 F600.000 E6.90480
G1 X104.596 Y95.362 F600.000 E7.23285
G92 E0
G1 Z9.500 F7800.000
G1 X104.638 Y95.505
G92 E0
G1 Z10.000 F7800.000
G1 X95.505 Y104.638
G92 E0
M107
M104 S0 ; turn off temperature
G28 X0 ; home X axis
M84 ; disable motors
; filament used = 128.3mm (0.9cm3)
          • Heart
        • 7 replies
