extruder motor react when using option "moving axis"
kneuver
Posted · extruder motor react when using option "moving axis"
Is the Ulticontroller broken or can I get new software for the Ulticotroller?
I can NOT print with using the SD-card but I can print directly from my computer with the USB cable.
If I use the option ''moving axis'' - ''moving extruder'' the extruder does not respond.
I'm using Ultimaker original and updated the latest Cura (14.03) and installed default firmware.
    • 2 weeks later...
