Daid,
Thanks for responding.
After I got my machine assembled, I tried using ReplicatorG at first and had updated the firmware through there. Is the firmware for that vs. Cura different?
Yes, the gcode was generated using Cura.
Maybe I will try the Cura firmware tonight if you think that will help.
Thanks,
David
Daid 305
The extrude button in PrintRun should extrude a few mm of filament each time. It it only moves a tiny bit, then you might be using old firmware. Did you upgrade to the firmware supplied with Cura?
The "e_feedrate" setting is 300mm/s per default, it's also shown near the extrude button on the lower left. The default is fine. And this value is never used during printing.
Did you generate the GCode that you are trying to print with Cura?
Alternatively, try entering "M92 E865.888" in the immediate window at the lower right corner, before printing/extruding. To see if this makes a difference.
