Posted · Cura firmware upgrade makes ReplicatorG "out of order"
Hi all,
I'm newby of Ultimaker world.
I've just assembled my first Ultimaker and now I'm trying to print a real 3D thing...but I have some problem.
I cant' print neither using Netfabb nor ReplicatorG nor Cura.
My last try was Cura. I updated the firmware (as suggested by the Cura install setting). But I was not lucky and even Cura didn't work with Ultimaker.
So I tried to use again the ReplicatorG but it didn't work anymore because of the firmware I've installed with Cura.
Now I'd like to go back to the pre-installed firmware fo Ultimaker/Arduino but I don't know what version it was.
I've tried to download some version from "firmware.ultimaker.com" but I can't update the firmware, even if I try updating directly the Arduino board.
Please, anyone can help me getting out of this issue?
Thanks in advance
Regards
Luca Mazzotti
    The cura firmware works in RepG if you enable the "experimental machine" option, and then select "Experimental sprinter/marlin"
    Note, if Cura didn't work for you, you might ran into this bug: viewtopic.php?f=8&t=855 there is a workaround for it.
