Cura 14.07 doesnt want to add support pillar
misha-lytvynyuk
Posted · Cura 14.07 doesnt want to add support pillar
Cura 14.07 doesn't want to add support pillar, Im trying to print model from Thingiverse and in case 90deg overhangs It doesn't add support structure no matter what I do!! Slicer in same time add support properly.... But I want to make it work in Cura.
I have single extruder setup
Please help.
Sharing sample stl file.
https://www.dropbox.com/s/5vflvndj62a64rd/mMW-Hub.zip
    Think I messed up the comment or implementation on the overhang angle, as with 0 degrees it does support the parts you want.
    Did not catch what you mean about 0 deg, but part was created upright (fins were vertical) so I rotated it 90deg and placed on the build surface flat, is that what caused confusion in Cura ?
        • 26 replies
