Titus 170
ouch! I was so close to doing the same. Glad I stopped at the right moment.
I'd say you need a new brass pipe and the peek. The Teflon, heating block and nozzle will be ok.
Just heat the aluminum and use a wrench to get the brass out of the aluminum block
