Temperature of extruder drops at start of build
currents
Posted · Temperature of extruder drops at start of build
Hi All,
I am trying to print my first test model on a new Ultimaker and I can set up the temperature from the Replicator G Control Panel, but as soon as I try to run the gcode, the heater turns off. Have tried everything that I can find in the settings, but the problem always occurs. I'm using version 0035.
Any ideas please?
Thanks!
Terry
    • 1 month later...
    Hallo,
    in gcode there are lines of code to set the temperature. Some/all slicers (not cura) will input this line with values from preferences.
    So after start the heater will change temp.
    • 2 weeks later...
    The built in Slic3r profiles are made to create a hot first layer and (sometimes) cooler subsequent layers.
    * I figured it was a way to ensure proper adhesion with the tape.
    In RepG: GCode -> Edit Slicing Profiles -> (select a profile and press edit)
    If the set temperature is too low for a given PLA/ABS you can duplicate a profile and make it more specific to your needs.
        • 27 replies
