CuraEngine size is half
mhk3000
Posted · CuraEngine size is half
Hello Daid,
When I am using package.sh to build Cura.exe, the size of CuraEngine.exe is approximately half compared to CuraEngine.exe packaged with the release version from software.Ultimaker.com. Gcode toolpaths within my CuraEngine do not work on any machine other than the build machine
I have shared a link of package.sh
https://www.dropbox.com/s/9e1pgmbzrpsv889/package.sh?dl=0
And I have commented only the following lines
#package the result
if (( ${ARCHIVE_FOR_DISTRIBUTION} )); then
if [ $BUILD_TARGET = "win32" ]; then
#rm ${TARGET_DIR}.zip
#cd ${TARGET_DIR}
#7z a ../${TARGET_DIR}.zip *
#cd ..
#if [ -f '/cygdrive/c/Program\ Files\ \(x86\)/NSIS/makensis.exe' ]; then
rm -rf scripts/win32/dist
mv `pwd`/${TARGET_DIR} scripts/win32/dist
'makensis.exe' -DVERSION=${BUILD_NAME} 'scripts/win32/installer.nsi' >> log.txt
mv scripts/win32/Cura_${BUILD_NAME}.exe ./
# fi
else
echo "Archiving to ${TARGET_DIR}.tar.gz"
$TAR cfp - ${TARGET_DIR} | gzip --best -c > ${TARGET_DIR}.tar.gz
fi
else
echo "Installed into ${TARGET_DIR}"
fi
    Daid,
    thanks for your reply. I have installed Codeblocks and still getting the following error. Also I am using a windoww 7 operating system
    C:\Github\CuraEngine>mingw32-make all
    The syntax of the command is incorrect.
    mingw32-make: [build/] Error 1 (ignored)
    mingw32-make: [build/modelFile/] Error 1 (ignored)
    mingw32-make: [build/utils/] Error 1 (ignored)
    g++ -c -Wall -Wextra -Wold-style-cast -Woverloaded-virtual -std=c++11 -DVERSION=
    \"DEV\" -isystem libs -O3 -fomit-frame-pointer -march=pentium4 -flto src/bridge.
    cpp -o build/bridge.o
    Assembler messages:
    Fatal error: can't create build/bridge.o: No such file or directory
    mingw32-make: *** [build/bridge.o] Error 1
    • 2 weeks later...
