Broke my PT-100....
jin1219ca
Posted · Broke my PT-100....
Was disassembling the hot end to tighten everything for leakage problem, everything goes well but in the end I pulled out the PT 100 with pliers which is still hot due to the warmed hot end. The PVC covering then dissolved and then fell off.... too bad.
Can I know may I fix it with anything or can only order one from Ultimaker? Also, the PT 100 for my UMO+ is the same as the Thermocouple Sensor?
Thanks.
