Posted · CuraEngine Build Error 1
After finally getting MinGW to work, I now face this build error. Could someone help me with this?
g++ -c -Wall -Wextra -Wold-style-cast -Woverloaded-virtual -std=c++11 -DVERSION=
"DEV" -isystem libs -O3 -fomit-frame-pointer -march=pentium4 -flto src/bridge.
cpp -o build/bridge.o
In file included from c:mingwlibgccmingw324.8.1includec++cmath:44:0,
from src/utils/intpoint.h:16,
from src/sliceDataStorage.h:5,
from src/bridge.h:5,
from src/bridge.cpp:2:
c:mingwincludemath.h: In function 'float hypotf(float, float)':
c:mingwincludemath.h:635:30: error: '_hypot' was not declared in this scope
{ return (float)(_hypot (x, y)); }
make: *** [build/bridge.o] Error 1
Does it have something to do with the include files MinGW is using?
    Thank you! After getting rid of the -O3 option, it builds without any errors! You must remove the -O3 option located in the CFLAGS tag in the Makefile. I think it's under the Profile if statement.
