G4 pauses in 4a Low Quality profile
cyclone
Posted · G4 pauses in 4a Low Quality profile
I've noticed that the infill produced from NF 4.9 using the 4a Low Quality profile / material adds a bunch of G4 P10 and G4 P60 lines.
Does anyone know why that is? It prints fine but the machine runs and then quickly stops and hesitates a lot during a print. I'd like for it not to do that. The point of LQ is to print faster, or so I thought.
I've looked at the words in the Build Style dialog and even compared them with the words in a non-G4 adding style and it seems like there is no "add a pause for no good reason" checkbox that I can uncheck. :)
    After a bit more time looking at the gcode the G4's seem to be around non-existent filament retraction code.
    If you go in and put a value > 0 in the RPM for Push On and Pull Off it adds several lines of code with the G4's.
    Is there a way to not put these if the RPM for retraction is 0? Removing the G4's removes the strange pausing
    behavior (obviously).
    I really think this is new behavior with the last update.
