Reordering of items on the bed
alex-barker
Posted · Reordering of items on the bed
Could someone tell me a way of reordering the print-one-at-a-time sequence?
I have a clean layout of keyrings and dont want to adjust them by hand. As you can see in the screenshot, it has a wonderful way of ordering items on the bed. Seems a bit unlogical:
https://www.dropbox.com/s/mclbm2dt6eubqc8/Screenshot%202015-02-18%2002.39.18.png
Problem is, it must go from front-right to back for each row, otherwise the fan shroud will get in the way :) I have set my "head size" under machine settings to very small so that it would work with this spacing. I tried two next to each other and that works fine.
I tried to hack the gcode, but there is a command at the beginning of each segment that tells the print to move to the wrong place. e.g.
;Layer count: 23
;LAYER:0
M107
G0 F9000 X163.442 Y21.870 Z0.200 <--- This one here I think is the problem
;TYPE:SKIRT
G1 F1200 X163.625 Y20.738 E0.01438
G1 X163.882 Y19.615 E0.02883
G1 X164.211 Y18.513 E0.04325
G1 X164.585 Y17.505 E0.05673
Is this line of code really necessary? Can I leave it out?
It would be nice feature to click on the item on the bed and set its order with a simple index.
Any suggestions are well appreciated :)
