Slic3r 1.1.7 Config File adapted to UM2
fergazz
Posted · Slic3r 1.1.7 Config File adapted to UM2
Hi everybody!
I`ve love Cura but sometimes I need to validate some model (e.g missing walls) or change some support settings to get better prints. After some seach I found NetFabb, Slic3r and Kisslicer as options to fix some of those problems. Reading some topics in UM Forum I choose Slic3r to be my plan B, but I`m having some problems to set the Printer Settings.
I would like to know, someone have a Config File adapted to UM2 to help me with print parameters and filaments settings?
I downloaded a Config File for slic3r but it doesn`t fit in UM2 propose (e.g 0.5 nozzle and printable area with diferent size).
I read some old posts about Netfabb, looks like the best slicer but they don`t support UM2 anymore... I wonder if even without this support it runs smoothly and what can be wrong?
Extra tips to validation STL models are welcome <---
Cheers!
    • 4 months later...
    I'm sorry I don't have an answer for you, I have just started looking into this (config files for Slic3r). I hope to have something useful I can post in a week or so. Have you found anything that works in the interim?
    • 5 months later...
    ... I hope to have something useful I can post in a week or so. ...
    Any luck? I'm facing the same issue here. I would like to start using Slic3r, but the lack of correct Ultimaker2 settings is keeping me from it.
