Alright David, I will give it another go as soon as I find some good ones that won't sag with time and use.
Belts shipped with the UM shouldn't sag with time and use, but they are a bit to lengthy, so you have to add some belt tensioners. There are a few designs for those on thingiverse.
So I tensioned all the belts including the ones for the motors. Now I am getting proper circles and infill BUT!
The part in the picture where there is a vertical absence of infill still occurs. Its as if the software doesnt want to get close to the perimeters. I did notice that the first 1 or 2 layers are almost perfectly filled in.
I did mess around with the speed during the build and still same result. I also changed parameters one at a time with no success. I have no idea whats going on any longer. But I am glad that the prints did improve even if not all the way.
I forgot to mention that one place I didnt investigate was the extruder. It does extrude and I figure since the actual infill is like 99% maybe the extruder is fine.
The design of the extruder is another matter. When the wheel retracts the material it has too much play in the Boaden tube thing. Anyways any help with that perimeter and infill gap thing and she's 100%.
So i'm printing circles without any problems still, but the perimeters around them wont join with the infill. Any ideas?
Daid 298
I recommend you look at your belt tension first, I can clearly see that your circles are not round and they should be. This is almost always because you don't have enough tension in your belts.
