Cura 15.02.1 in Windows 8.1 64
ews
Posted · Cura 15.02.1 in Windows 8.1 64
Hi everyone,
I am on the process of ordering an Ultimaker 2 very soon and wanted to have a look at Cura before.
Download and setup OK but when i try to start it, the splash screen stays here until i click somewhere else and then nothing happens.
Had a look in the preference folder and saw a log file, filling up with some errors as below :
Traceback (most recent call last):
File "C:\Program Files (x86)\Cura_15.02.1\python\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py", line 14660, in <lambda>
lambda event: event.callable(*event.args, **event.kw) )
File "Cura\gui\splashScreen.py", line 15, in DoCallback
self.callback()
File "Cura\gui\app.py", line 103, in afterSplashCallback
from Cura.gui import mainWindow
File "Cura\gui\mainWindow.py", line 17, in <module>
from Cura.gui import sceneView
File "Cura\gui\sceneView.py", line 28, in <module>
from Cura.gui.util import previewTools
File "Cura\gui\util\previewTools.py", line 12, in <module>
from Cura.gui.util import openglHelpers
File "Cura\gui\util\openglHelpers.py", line 17, in <module>
glutInit() #Hack; required before glut can be called. Not required for all OS.
File "C:\Program Files (x86)\Cura_15.02.1\python\lib\OpenGL\GLUT\special.py", line 323, in glutInit
_base_glutInit( ctypes.byref(count), holder )
TypeError: 'NoneType' object is not callable
I am running Windows 8.1 Pro 64 Bits
Did someone already encountered this problem ?
Thank you
    Small update : problem solved.
    Had an installation of Haskell on this computer that overwrote a DLL
    Juste removed it and now Cura starts without any problem.
