Glue PLA with acrylic glass
Posted · Glue PLA with acrylic glass
Hello,
I want to build a heat chamber for my UM2 and I will need to join the acrylic glass plates with my PVA printed parts.
Which glue can I use to glue those two materials together?
I have this 2-component epoxy resin adhesive at home. Can I use this or will there be a problem with it?
http://www.uhu.com/produkte/2-komponenten-klebstoffe/detail/uhu-plus-schnellfest2-k-epoxidharzkleber.html?cHash=4991be4bff8461631f0f903c2a966e73
