Not closed fill in cura?
x3nomorph
Posted (edited) · Not closed fill in cura?
Hello,
can someone tell me why is cura sometimes filling the layer 100% and sometimes not.
https://www.dropbox.com/s/apyzl00g61i8en5/1.png?dl=0
https://www.dropbox.com/s/vzncx4y18r7knk0/2.png?dl=0
Same settings, sometimes i just need to change the layer height from 0.1 to 0.11 or smth
Thanks in advance
    Posted · Not closed fill in cura?
    I have seen this with altering the z hop. Also when you change the layer height from 0.1 to 0.11 etc.. are you also changing the top/bottom thickness to match? It need to be the layer height multiplied by 6 or 8 times etc..
    @DidierKlein
    I tried with infill value of 99% and 98%, its the same, lowering it more it disturbs my model.
    @labern
    i have zhop (expert settings) mostly off, but on in the retract while combing plugin. hmmm i didnt changed the t/b thickness and i didnt know that it need to be multiplied. My top and bottom thickness is 0.8 in 95% cases, the LH is changing in 0.1/0.15/0.2.
    well thanks for the advices.
    in the end i just refreshed few times the slice and it worked well... btw using cura 14.12.1
