Posted · Cura won't launch - No module named numpy
I've just tried to install Cura and can't get it to run. Running cura.bat from the command line shows me this, which appears to be some issue with Python but not my area of expertise. Any suggestions much appreciated...
Traceback (most recent call last): File "C:\Python27\lib\runpy.py", line 162, in _run_module_as_main   "__main__", fname, loader, pkg_name) File "C:\Python27\lib\runpy.py", line 72, in _run_code   exec code in run_globals File "C:\Program Files (x86)\Cura_15.02.1\Cura\cura.py", line 13, in     from Cura.util import profile File "Cura\util\profile.py", line 22, in    import numpyImportError: No module named numpy
    So I finally managed to resolve this, I had two versions of Python already installed which seemed to be causing some issues. I was unable to uninstall them for some reason so resorted to precariously ploughing through the registry removing any traces of python and eventually managed to get Python and Cura to uninstall and reinstall.
