333 -
2
Just found this,
"Kapton ® Tapes are made from Kapton ® polyimide film with silicone adhesive. They are compatible with a wide temperature range as low as -269°C (-452°F) and as high as 260°C (500°F)" http://www.kaptontape.com/
I don't know if it is considered safe to run Kapton as an insulator if you'll be printing 260 C all the time. You'll basically be running the tape at it's maximum thermal limit constantly. Will have to do some more research on that, but I thought I'd share.
great tip, thanks for sharing
For some reason, The images are posted in reverse order. They were in the correct order when I wrote this...strange
As Murphy's Law states "What can happen, will happen". And wouldn't you know, the day after I order a second UM2, my primary UM2 gives me the screen of death, "Temperature error, contact Ultimaker". Well, I'm on a deadline, and my backup printer wont be here for I'm guessing 10 days or so, so I had to do something. So here's what I did.
First, I read the forums. It was suggested to set the advanced mode to "HEAT UP NOZZLE", so I did. Then I started to wiggle the wires until I got the screen of death. Problem was found on the heater block itself.
(I was more focused on fixing the printer than writing a tutorial so you'll have to excuse the lack of good photos)
Next, I disassembled the print-head unit, giving me access to the heater block. From there I removed the heater block using a vise. It was stuck pretty good. Don't forget to remove the set screw that holds the heater filament in... not sure if it holds the temperature probe in...couldn't get a clear visual on weather the hole cut into the probe side or not.
Finally got it out. This image already has the chip removed, but we'll get to that
Next came the indispensable Dremel tool with a very thin cutoff wheel. I very lightly, and very carefully cut into the probe head so I could remove the internals. I did NOT cut all the way through. You can tell when it is far enough because the metal is very thin and takes on a different appearance.
Once the housing was sufficiently split, I carefully pried the shell open far enough that a little light gray plastic looking wad came out. Once I unwrapped the little plastic looking wad, I was ... let's say shocked... that the problem was so tiny. I mean TINY! I immediately cleaned the entire room, vacuumed the floor twice, locked all the doors, and turned the air conditioning off. I simply could not afford to lose this tiny little sensor.
Here it is next to my small razor knife. Yeah...it's tiny.
So, I went about the tedious task of preparing the wires for repair. I pulled the cover off the main board, removed the thermal tab from the board, pulled the wire through the black flex sleeve (knowing that I was going to have to run it back through the sleeve was a downer).
I cleaned the wire up by cutting a little off the end, and stripping the 2 red wires and one clear wire.
At this point I knew the 2 red wires shared a pole on the sensor, and the clear wire had it's own, by looking at how it was wired to the main board. But I had no idea if there was a certain order, so I did a simple "hold them wires on there and see if it'll start" trick. so I temporarily wired up the real "always on" fan so the board would boot, and I don't know if I wasn't holding the wires tight enough to the sensor, but it didn't work the first time (at this point I'm freaking out), Then I switched poles, and SUCCESS! It booted.
I could not, for the life of me, figure out what to use as an insulator material to isolate the red wires from the clear wire and all the wires from the brass hot end. Every thing I looked up had max temp ratings well below 260 C . In the end, I cut a piece of office copy paper about 5mm by 25mm. Basically a little sliver of a piece of paper. I slipped it in between the 2 poles ,or wires, or the 2 silver things that stick out of the sensor...keep up with me here, and and began to wrap the wires. I came up with 25 mm because that's how much paper it took me to create a wrap that was slightly larger than the probe hole on the brass hot end.Then, I carefully twisted it in to the probe hole. Yeah...had to take it back out because I had to feed the wire down the black hollow plastic head unit. Duh...
Short story long (too late) It is possible to do an emergency repair on this sort of thing. Yes, my printer works fine now...yes I have not 1, not 2, but 3 fire extinguishers next to the damn printer now. Yes I learned a lesson, MAKE SURE WHEN YOU DISASSEMBLE YOUR HEAD FOR REGULAR CLEANING THAT THE TEMP AND HEATER WIRES DON'T PROTRUDE FROM THE BACK!!! When the printer homes the head, it will smash those wires against a hot stepper motor...over and over and over again, until the wire fails. I am curious as to how long a quick repair, using office paper and a zip tie to bind the heater wire with the sensor wire, will last. Rest assured I will be contacting Ultimaker for a replacement ASAP.
Hope you enjoyed, I know there's steps missing, and explanations that are vague, but when your printer is down, and you have a deadline to meet, the last thing on your mind will be "Hey lets make a tutorial on jury rigging a temp sensor", unless you're like me (which a lot of you probably are come to think of it)
gr5 edit: reversed the images to what I think they are supposed to be.
As they say here in the States, "The squeaky wheel gets the grease." That is, as customers, we complain, and as a business, Ultimaker applies the grease. I really hate to complain... it's just not my style, but in this case I have to. The Ultimaker 2 was clearly designed for dual extruder use. The FAQ page lists the second extruder as coming out July (now Late 2014). I believe it was listed on the actual UM2 product page at one point. All of this points to one thing, customers expect a second extruder available soon. What's to stop Ultimaker from simply changing the "Late 2014" to "Spring "2015"? It's already been done once, "Mid 2014". Don't get me wrong, I just bought my second UM2. I am happy with the machines performance... happy enough to buy a second, and soon, a 3rd UM2. Print quality and speed were major factors in placing another order, but the second extruder is also a determining factor. I realize that it's still early to be complaining about expecting a second extruder when the release date has been moved to "Late 2014", but reading all these comments about problems, delays, "we never said we'd have a second head" -paraphrasing , has concerned me enough to post this.... so, I say to you Ultimaker Squeak ... squeak ...squeak, time for some grease .
P.S. I don't agree with most other people here when they say they'll basically wait indefinitely for the 2nd extruder as long as it works when it's shipped. But that's just me Keep up the great work Ultimaker
I just noticed that the estimated realese date for the UM2 dual extrusion kit was listed as "Mid 2014" and now it's "Late 2014".
I don't want to sound like I'm complaining, but REALLY!!!!! That is disapointing to say the least.
Tweaking the UM2 nozzle for better extrusion
in UltiMaker 3D printers
For what it's worth, I recently had to disassemble the brass heater block for a sensor repair...I removed the temp sensor probe and heating element. I went ahead and blasted the brass block with a propane torch until nothing was left to burn. I did a quick scrape down, nothing fancy. I reassembled ( it still had black oxidation on the inside of the extruder nozzle because I didn't have time to Q-tip polish the darn thing) and I must say, I noticed a remarkable difference in extruding...no curling, clean extrusion rates, etc. I usually use the "atomic method for quick cleans"
Just thought I'd pass that on.
EDIT: I've since had to clean the nozzle, and this time I did polish the inside with a widdled down q-tip stick, a drill and some "Never Dull" brass cleaner. Worked awesome, and is a real confidence booster knowing the inside is so smooth and shiny
