Posted · 3DP Meetup #10 (Oslo, Norway) June 6-7th 2015
The coming weekend we're kicking off our tenth 3D Printer Weekend at the Bitraf Hackerspace, downtown Oslo. If you're nearby, please drop by!
In addition to the two Ultimaker Original's that are the hackerspace's main workhorses, there will be a good mix of other printers such as the BAM (BigAluMendel), Mendel90, TwoUp, Cube, Makerbot's, MakergearM2, Rostock plus, printrbot, Thing & more. This will also be the first weekend that our full-size CNC is operational, so with the X700 laser cutter it's a perfect opportunity to mod and fix your printer. Among the plans are a cutting a permanent "top" to the in-house Ultimaker Original's so they both can hold the heat in when printing ABS. Bring your machine(s) and come join us!
PS: If you're into Cosplay, there's a Cosplay meetup the day before :)
          • Heart
        • 4 replies
