Is printing from NetFabb stable? I didn't think it was. I think the recommended action is slicing with NetFabb and then printing it with PrintRun. Cura installs a 250000 baud firmware by default, so you need to configure PrintRun or NetFabb to use that baudrate.
The other way around, Cura will work fine with a NetFabb capable firmware. As the baudrate in Cura is auto-detected by default.
codemaven 0
Hi Thomas,
When you try to connect is there an error message, or does it just hang? My guess is that the buadrate is incorrect. I believe Netfabb and Cura default to different baudrates. You will need to set your firmware to a specific baudrate and then select that same rate in the settings for both NetFabb and Cura.
Cheers,
Troy.
